Fredastaire
- Joined
- Dec 19, 2017
- Messages
- 415
- Points
- 127
The position sensor is in the cover plate of the LP EGR, it's got a sticking out probe. In the driven gear there is an eccentric hole. I think the sensor is a 'hall effect' component that is measuring the air gap.
The only way I see to get the cover off would be to cut a hole in the van floor about where the passengers feet are, then fit a plate over before refitting the cab rubber mat. It's very drastic, the option to undo the LP EGR to get at it to change the cam or remove the butterfly needs the DPF removing, we all know how difficult that procedure is.
To undo the elbow duct / pipe of the LP EGR can be done by removing the battery box......tricky but possible. With the auto you can't reach the electric connector........
