Throttle cable fitted..?? Looks like it, I think it is a throttle cable, which is then connected to a pot which then sends the position to the ECU by measuring the resistance.
how OLD IS the battery..??, As old as the car, 4.5 years old always starts instantly even when not been used for a couple of weeks, and the voltages are all perfect according to my scope, so would be surprised if it was the battery. This is the only fault I have too.
Jim did you have exactly the same problem in that there was no ECU code too? I would have thought if it was an ECU connection problem there would be more symptons?
99.9% the car runs like a dream, so I very much doubt it is a coil pack/HT lead/plug problem etc. Put there have been other odd little things that have happened, which may when I think about it turn out to be a connection to the ECU problem.
