Technical no gears 3.0 Ducato comfortmatic
Buzzsinger
Wales
Hi all ....have a Comformatic gearbox 3.0 robot Ducato. Broke down with the dreaded neutral ... No gears ...pump relay prob etc ....sub clutch P2904 fault code . Well just a heads up .....the master cylinder became dry (no dot 4 in resivor ) noticed that the clutch sensor was leaking and that the rubber seals had become dry .....new o ring seal and rubber grease and clutch bleed / reset learn for gears using multiescan .. fixed 👍
The clutch sensor is this one you need to mark the position to then fit a new one you twist 90 degrees to align holes
