Technical Ducato 3.0 2016 comfortmatic
dagbj
Hi
Fault code:
P1756-13 gear electrovalves circuit open.
Bad connection, wiring to solenoids maybe.
But which solenoid does it refer to?
Any other causes?
Model
Fiat Ducato
Year
2016
Mileage
88000
If you use multi ecu scan you may get further two numbers on code identifying which solenoid circuit showing faulty.
Sorry I don't know why I didn't see you had put the extra two numbers on your first post.
Yes something like that but remember p1### are specific meanings dependant on the manufacturer .
Your p1756 fiat meaning appears to be for odd numbered gears engagement solenoid circuit
1,3 and 5gear?
Yes that's what it looks like in the code definition table for the fiat 500 selespeed system-code definitions "should" be the same because it's fiat definition.
You know where to get parts list and manuals for selespeed cfc 348?
Some info from web and supplier of most parts. might be worth an email :-https://www.sequparts.com/product-category/fiat/fiat-ducato-comfort-matic/?gad_source=1&gclid=EAIaIQobChMI_buQg7m7iQMVxZhQBh1kfQYDEAMYAiAAEgIjhPD_BwE
get to eper and search for transmission and gear box. there are 2 types of solenoid and 2 of each are required
  • Comfortmatic+Gearbox+Problems.pdf+·+version+1.pdf
