- Joined
- Aug 11, 2021
- Messages
- 122
- Points
- 104
@theGman with a clean exhaust it's highly unlikely that you have a duff DPF. What is the van mileage, what is the replacement engine mileage? .
Back to basics I recommend an intensive viewing of the intercooler hoses and the intercooler itself, take the air cleaner cap off and check the air filter for rodent nesting. Check the turbo solenoid plastic vacuum pipes.
If all ok I would next go for a run with MES running live data and watch the LP EGR opening requested / actual. Downhill foot off it should be closed, foot dowñ it should re-open. On the run you should see it fluctuating between say 2mm and 3.9mm to show it is varying itself to suit engine demand, the LP EGR temperature should equally vary between 60 ish closed and 100 +-10 as you drive. This indicates a clear enough cooler. If you see it either closed or 4.7 open (ie fluctuating between closed or fully open), then the cooler looks blocked.
If this proves ok then no hesitation change the turbo solenoid and MAP sensor, cost circa £100 and a little diy work.
Hi @Fredastaire , the engine, turbo and all injectors were replaced December 2021 due to engine failure, “insufficient oil pressure” then seized. In our last trip the engine went into limp mode, told Fiat Professional garage that the AA recovery scanned ecu and had errors 0236 & 0238. They replaced the MAP sensor in August but said there was another issue and had to contact Fiat Italy. An hour later I got a call saying van ready to collect. Then last week van back into limp mode with P0238 error. The replacement engine was supplied by Fiat Italy and has done about 10k miles now.@theGman with a clean exhaust it's highly unlikely that you have a duff DPF. What is the van mileage, what is the replacement engine mileage? .
