Fredastaire
- Joined
- Dec 19, 2017
- Messages
- 415
- Points
- 127
Can I bring some comments here.
It is me who started this thread.
I've been though all of this with our 2017 Comfortmatic that I ordered as new build from my Fiat dealer. I've designed and built my camper layout and maintain my own van and car. I've over 50 years of car repair / rebuild / maintenance experience.
These twin EGR no adblue vans are showing multiple problems some related some probably not. Fiat are understood to have realised they has software problems leading to overfuelling which damages components thus there have been revised softwares having reached v32 which has been installed in many vans since about 3 years. As they havnt changed it in those years we can only assume it's 'good'.
It's clear that many vans are surviving ok having probably been updated by their dealer unknown to the owner. Then there are those of us with ongoing problems because of damage in early times.
The original software overfuelling can wreck injectors which in turn wrecks the DPF which in turn clogged the LP EGR cooler and also blocks the intercooler and sometimes the front throttle body.
Separate the turbo solenoids begin to fail at every 25k miles causing hesitatiowastedn and fault codes.
Separate the MAP sensors clog up, also note the factory is known to have fitted wrong part number sensors.
Separate some vans have a problem of wiring harness rubbing body parts and slicing through cables.
Where am I in all this? I now only run high spec diesel 'ultra' and always use Millers additive. I've wasted time replacing the HP EGR because the fcr incorrectly told me so. I've replaced the MAP, the turbo solenoid and finally replacer the LP EGR cooler. My exhaust is slightly sooty which suggests the DPF is cracked.
I'm clear of fault currently and await the next round....
@theoneandonly can add comments.
Conclusion - 1/. it's a must that you buy and use MES 2/. You need to know your injectors are within Fiat running spec, 3/.you need V32, 4/.only buy quality 'ultra' spec diesel.
I look forward to comment's
