This does not refer to earlier single EGR systems or to later AdBlu SCR engines. Note this is a guide and not definative. It is up to you to make decissions. It is the result of my investigations of data from many contributors and discussion with...
www.fiatforum.com
How to diagnose a problem the DPF Differential Pressure sensor and its impact on the DPF. known in
mes parameter list as Differential Pressure Sensor. These sensors are prone to any debris or condensation in the exhaust, which can cause the...
www.fiatforum.com
These are 2 tutorials that I wrote. information from mine and other engines.
From here there are examples that examines freeze frame data from 6 engines and multiple from one that shows all indicate the same issue. The 401 error always coincides with a large demand and inability to deliver it.This is due to an ecu error or air flow not being possible due to another condition.
The LPEGR position and cooler have been charecterised. In a poorly system the EGR valve is either trying to be fully open or closed, the LPEGR cooler temperature is very low compared to a working system. Details are in the tutorials.
The differential DPF sensor is also good at showing health of system and is used by fiat in its regen control methodology. Look at videos on Utube about cleaning the dpf insitu they all use scan tools looking at this sensor. The regen data is just about ignored.
The one thing i dont do is give a method to create a number and then say bellow this bad above this good
The knowledge on these engines grows with time and changing test methods. The area where we are lacking in understanding is Injector values and how these interact with other issues of sooting. On a gross perspective we were able to indentify bad injectors leading to DPF clogging.
The HPEGR valve sticking is an important issue to address and i now have different parameters i d like to monitor to help with this. kNowing when a code has been thrown helps understand the anonamolies on a graph.
There is a limit to the number of pids that can be measured and limited documentation to suggest what to test.
I am limited by the information that others will provide since i don't have a problem and am doing my best to avoid a problem.
