Step 4
Step 4 – Prepare headlamp sealing cover
Cut a hole in the back of the headlamp cover to accept the rubber grommet for the HID kit. You will need to ensure that you cut the hole slightly off-centre otherwise there will not be room behind it for the bulb and additional wiring when fitted to your B.
Feed the bulb through the new hole (being careful not to touch the glass) and fit the rubber grommet to seal the until.
