Step 2
Step 2 – Test kit and fit bracket
Test the kit before fitting by repeating the wiring required to fit the kit to your B off the car (follow the diagram in the manufacturers instructions). I suggest using the current supply from your headlamps, the wiring for the new kit utilises the positive/negative feed from the standard lighting circuit by being provided with opposing male/female connectors.
NOTE – Make sure that the bulb protector is removed and the kit is insulated from earthing – these kits can kick out in excess of 20k volts (they can kill you).
When you test do not touch the setup while it has a live feed and make sure the bulb is suspended and the wires are insulated.
