I got the second brake on this morning without any problems, i decided to cut the big spring because i had a spare and i was worried about damaging the wheel cylinder while getting the shoes off. The main issue I had was with bleeding the brakes, the regular spanner i'm using doesn't have good access to the bleed nut so i'm struggling to nip it up in time because it'll only do a micro turn before having to come off.
The brake fluid I took out today looks a lot worse than in the other back brake line, it was coming out all milky and has turned the more or less clean dot 4 that was in this bottle kind of murky. Is there are any reason for this?
On a side note my wife was around today and so I got her to pump the brake, but then nothing was happening so I go to see what she's doing and I can see her foot on the accelerator pedal. So I said "you're supposed to be pumping the brake" and she replied "Oh yes, sorry, I was pumping the accelerator, and also the last time I helped you!" Then she laughed with uproar. I can see the funny side of this
