There's a big bolt in the very first post pic would it be possible to fashion a "retainer" that pulls in into place, there's enough thread to just put another nut on?
Mine can be slowed right downA dremmel is way to fast, and I'd be concerned about the amount of force I put on it.
I think I'll leave that one for the garage if it comes to it!One more thought, if you fail to drill out the existing bolt / weld or whatever it is, is there room to drill and tap holes either side of the old bolt. (Assuming no webs or oil ways).
Thanks all. In the event of me being unable to remove it, a few Qs:
- I've seen a few people recommend using a jack to compress the RTV as tightly as possible on that corner. Surely that could lead to it leaking in the future? - i.e. the sump will "want" to pull away in that area because that pressure bent it into an abnormal shape?
This feels completely wrong to me. because you can't replicate the force of the missing bolt once you take the jack away.Your looking to replicate the force of the missing bolt while the RTV sets.
I think the logic would be that it holds that corner in place as you torque up the other bolts, That is, that corner might bend down without a bolt in there, and the jack keeps the sump straight.This feels completely wrong to me. because you can't replicate the force of the missing bolt once you take the jack away.
Judging by reviews, it’s an adhesive sealant so should be okay…and at least it would alright to drive to get a more permanent solution…see how it goesOK new sump is on, it looks good, if I apply pressure next to where the missing bolt is I don't see the sealant moving at all. I used Dirko. Going to leave it 2 days due to the cold weather so we'll see if it works in a few! Thanks for all your help so far chaps, much appreciated
I would have expected it to squish out the bolt hole and side as you tightened it up.if I apply pressure next to where the missing bolt is I don't see the sealant moving at all.
and more importantly leaking!Update, I just couldn't resist the urge to wait the full 48 hours so filled her up and tried her tonight after the recommended 24 ish... she lives! I've taken a good look around all the bolts after a test drive and so far no signs of oil leakage anywhere. Interestingly it actually idles way quieter now, I suspect removing that big RTV bogey from the pickup tube has helped.
Thank you all for your help, I'll update in the future as to whether it's still holding!
better double check theres actually oil in it!3 week update - no leaks.![]()
