sherbsville
oooh thats brilliant, thankyou so much. I defo need info on how not to get crushed by a car. I'm scared of it tbh. It happened on an episode of casualty decades ago, and I'm still traumatised.I'm sure you and Bubbles have many happy miles ahead together
To future - proof Bubbles make sure the rear axle spring pans don't get too rusty, just a wipe with old engine oil every oil change will add years to its life.
And have a look at steveras57's 500 guide here:
500 - Fiat 500! things you should check once you get your car home
This thread is for the general discussion of the Guide Fiat 500! things you should check once you get your car home. Please add to the discussion here. steveras57 submitted a new guide: Fiat 500! things you should check once you get your car home These are the common problem areas on these...www.fiatforum.com
For advice on safely working under your car, can't do better than Jock's guide here:
Raising and supporting light vehicles (ie. cars) - some thoughts and observations.
I recently posted some stuff on jacking and axle stand use in the thread "What's needed to run Multiecuscan" and several people "liked" it and Herts Hillhopper said he thought it should be moved to the guides section. I took another look at it...www.fiatforum.com
They're both super friendly and helpful if you need anything![]()
There was something about corrosion on the back something as an advisory on the mot... Ok, just checked it says "rear axle corroding" and "rear shock absorbers has a slightly worn bush both upper bushes". The axle thing scares me, as I don't know what it means, like how worried should I be. It sounds scary. I will look under and see soon. Can I fix the corroding? Oiling it will help stop it getting worse, right?
When I took her in to get the bluetooth disconnected as it was draining the battery, (£215 quid gone like that. Nightmare) fiat did a health check, and gave me a nervous breakdown. I just read through it again, it was in July. It doesn't mention corrosion, but mentions front and rear near side shocks, and both front top mounts have play. They are insane with the prices, and frankly need to calm the beep down. I wouldn't go there anyway, but still.
On the checklist it says the master cylinder/servo are green, as in ok. So idk if that helps with diagnosis.
Anyway, I'm going to order the things I need so I can change the slave cylinder tomorrow, (unless it might be something else as the masters ok?) I've watched a couple of vids, If I have to take the battery out to grease the thing, I might as well change it. I hope it isn't all stuck together so I can't do it. The man in the video had everything go wrong.
Honestly, you are an angel. Thankyou so much for all your help.
