General Fiat 500 S won’t stay in gear
Zoephilly1
Bromley, Kent
Please help my Fiat 500 won’t stay on gear was fine yesterday and on the way to work! Now stuck at work. Any ideas what this could be? Thanks
Not stay in gear as in the gearstick goes back to neutral?
Can you hold the gearstick in place?
Not stay in gear as in dead clutch or no drive?
Not stay in gear as in broken gear selector cables?
"Not stay in gear" is a bit of an odd description for a manual, you'll need to elaborate a bit.
Ok,
Several options
Try with engine off, does the Grearstick move normally?
Try and select all 6 gears..
If that seems OK, start cars engine, try all 6 again
Is that different?
Sorry not a mechanic!!! Pops back to neutral when selecting a gear with engine on or off. No change with clutch peda
Ok,
Several options
Is that different?
It’s the same with the engine on an off gearstick moves just won’t stay in position pops back to neutral
