Technical fiat won’t go into gear.
bellaagnes
nottinghamshire
Hi I got my fiat 500 2014 last year and it started not going into gear properly, took it to garage and they suggested a new clutch. Got a new clutch in January and it’s still having the same issue 2 months down the line so isn’t looking like it was the clutch, anyone have any idea as to what’s causing this issue?
Model
500
Year
2014
Mileage
103000
I will try this tomorrow and let you
Simple disgnostic :
Engine off.. Try all 6 gears
Then with engine running.. try all 6
Is it easier with engine off
What engine, manual gearbox, can you select no problem engine off, clutch hydraulics well known to give your symptoms if 1.2 manual
yes 1.2 manual thank you for your help
