The sump on Rasputin was a PITA to remove and that's with all the bolts coming out reasonably painlessly. A couple started to burr up but anyways came out okay.
The sump itself had to be teased off using every pry bar in my possession and suffered fatal deformation during the process (someone had welded up some rust holes (really!
) so it was leaking and scrap anyway.
My view is that once stuck on, the gasket goo alone would be enough to hold the sump in place, although I guess over time and unscrewing the sump plug enough times would eventually have it start leaking.
Anyhow... bottom line is Life is too short. Unless you have a fetish for this kind of thing (i.e. aged under 50) I would just smooth down that area and fit the new sump with the remaining bolts. Use a bit more RTV on the dodgy corner to allow for any face damage.. perhaps hold it under tension while it sets, using a block of wood on a jack maybe.... but I think the other bolts will do the job and while this might be fulfilling to resolve.. it's probably more of PITA than the bang you will get out of it..
Ralf S.
Ralf S.
