General  Fuel System, 2.5d Sofim, 1990
mooro
My first post so hello all!
I recently purchased a motorhome on a 2.5 d Ducato base.
Very good service history etc. Never failed a m.o.t.
Accept I noticed at speed on motorways sudden engine cuts out - probabl fuel I thought.
Under the bonnet I noticed the fuel filter had been completley bypassed!
Sent it into Fiat, who serviced it , made the same comment, but didn't know how to proceed.
Suggested I took to a diesel specialist.
Before I do this I would at least like to attempt to connect the fuel system up as it should be - the filter has been replaced and inlets cleaned.
Can anybody confirm the order in the 2.5d fuel system?
Is it:
tank--->filter---->pump----->injectors
or
tank---->pump----->filter---->injectors
cheers,
john
Hello
I have the 2.5tdi Sofim 1991. I don't know why your fuel filter would have been by-passed but The sequence on mine from memory is as your second option:
tank---->lift pump----->filter---->injector pump
I cant check at the moment because I am away from it. There are fuel flow arrows on the filter top housing on mine. If you also have them it may help you a bit.
Good luck with it.
Phil
Thanks for that Phillip.
In the end I went for :
tank-->lift pump-->filter---->injection pump
and so far, fingers crossed, my problems seem to have gone away!
