Hi, I have a German import Hymer B544 ducato 2.5D, it says first registered feb 1991 but on the V5 also stated declared manufactured 1992.
Trying to get some info on which chassis I have for suspension parts (Q10,14 or18?!?) and also interesed in the gearbox.
My Vin is zfa290000*00040909 but doesnt find anything in
ePER
Now this is very dodgy speculation , but according to what i learned , the numbers are relevant to weight capacity . For example , the Q10 , is a 1 tonner , and i would further speculate this could also be a short wheel base .
Let me explain what happened to me . So a while ago , my van , a year 2000 , Hymer 584 , fitted with a 2.8 idtd motor , developed an issue with it's rear brakes . Parts where needed , so i ran to my local motorist centre , and yes , he asked me this exact question .
Was it a 1.4 , or 1.8 ?
I didn't have a clue what he was talking about so quizzed him . His answer was weight capacities . Now my van is a full coach build , like yours (actually the vans are sisters) , so i figured it would be heavy , and said 1.8 .
What ya know , they didn't fit , so back to the shop , we had a chat , and decided to order some a 1.4 , bingo they fitted . I would speculate yours will also be a 1.4 , or Q14 .
Since then , any chassis , brake , or suspension parts have been ordered as a 14 , and all have fitted with no problem .
Though i can't find anything to back this up , i have since surmised using , my knowledge of other makes of vans , speculation , and my own vans specification and max loading , the following ;
Q10 , 1 ton , short wheel base .
Q14 , 1.4 ton , short wheel base , with a possible option for long wheel base .
Q18 , 1.8 ton , likely long wheel base only .
Now a caveat here , i cannot back this information up in any way , or even point to any written material that would even try to back any of this up . So i would advise caution , if you do decide to use this information for your own gain . I pretty sure i'm on the money , but i'm not perfect . I have repeated my experience , hopefully for your benefit .
