@Fredastaire @theoneandonly
I own a 2018 150HP 2.3JTD Euro6B Ducato 290 with MTA. I have owned it since new.
I am the only driver and have maintained it myself. It has never once suffered any relevant issue or had any fault codes referred to in FCA Service News Bulletin 10.023.19. Recently (5 days ago) I had the ECM software updated from version 0024 to version 0032 and the TCM updated from version FEA09DAT to FEA10DAU as per that Bulletin. The vehicle has travelled around 32,000 km.
I have captured some data before and after the update. Of significance, I have captured the last DPF Regen under V0024 and the first DPF Regen under V0032. As can be seen, the profiles are so close they could be termed identical. The updated software does not appear to change the DPF Regen algorithm. I captured the V0024 regen using an Autel DS808, and the V0032 regen using
MES. It would have been nice to have captured both with
MES, but at the time I did not have
MES up and running. At least the data can be confirmed in
MES by the historical data supporting the live scan data.
Below are three snapshots of the V0024 regen:
Below is the capture of the V0032 regen:
Below is the historical data of V0024:
Below is the historical data of V0032:
To distil the above data as V0024/V0032:
Average distance between last regenerations: 675/635 km
Average temperature of last regenerations: 625/624.5 C
Maximum temperature of last regenerations: 658/653 C
Average duration of last regenerations: 398/403.4 S
So, what does V0032 address then if not the DPF regeneration profile?
It would appear obvious that the health of the injectors is absolutely critical, not just from the information in the Service bulletin, but specially from what has been exposed and recorded in this forum. I am beginning to suspect that the main difference could well be in the main injection period which
MES has no access to, only the Total Fuel Quantity (which the main injection period is the bulk of anyway). But it does not show the duration or injection variation during the period. The only way to see that would be by analysing the injector waveform with a scope, and it would need to be done on a chassis dyno for accuracy.
MES shows five injections periods, but only three are available – Pre, Pilot, and Post (same goes for FIAT’s own Wi-Tech). MAIN and After injection periods are not recorded. It would seem that
MES has these original 5 injection periods which may have been relevant to the original version of Multijets, but not for the later versions of Multijet ii onwards.
Have I noticed any difference? Well, it could be the placebo effect, but the vehicle just seems to run more smoothly and quitely – it seems less fussed – if that makes any sense.
One large noticeable difference is the update to the MTA gearbox software. The gear change is very much improved both in upshift and downshift. It now holds gears longer and the change is also noticeably smoother. So there has been very favourable changes to the gear change point mapping and also the clutch mapping and perhaps throttle control on the change point.
