Very peculiar problem, indeed.
Are you going to try another alternator?
Reconnect the two sides of D04 and measure the resistence between D+ and pin 25 of BCM.Come to think of it… D+ connector might need to be disconnected on alternator - or else last measurment is invalid. I may be measuring against the diodes.
Well,did some measurements and it does indeed disclose some facts. With D004 disconnected I measured resistance to alternator chassis - and it was actually 410kohm.
Key on engine not running must be Very low volts before the engine is started. Otherwise the body computer will know there’s a problem and not charge properly and shut the EPS offI’m tempted to say the lead is not connected at all but I am actually getting 13.8v through it with engine running. Anyway it’s a good find and must be resolved.
So,what do I do next ? Run a new lead ?
First I need to get under the car and check the cable connector in D+ and check the state of it![]()
CorrectReconnect the two sides of D04 and measure the resistence between D+ and pin 25 of BCM.
This is the only right measurement and you obtain few ohms
if the wire is ok.
Personal I think the wire is good and the Hella regulator is different from original alternator regulator.
If you post the car VIN I can tell you the partnumber of original alternator.
And you can look for a second hand one with same partnumber.
Last one I checked was 1.5k D+ post to alternator case no wires connectedCome to think of it… D+ connector might need to be disconnected on alternator - or else last measurment is invalid. I may be measuring against the diodes.
Ok,so at least you also got Kohms. I expected it to be lower though. Are you using a Denso on the Stilo ? I will pull out the large car jack and crawl under for the D+. I need to see what's going on under there.Last one I checked was 1.5k D+ post to alternator case no wires connected
Not the same as my Panda which has a similar circuitOk,disconnected D+ from alternator and measuring from there to pin 25 gives 0.3 Ohm. That should mean cable from inside to outside is good. Checked voltage once again and it's still 9.8v ignition on/engine off and same voltage with D+ alternator connected or disconnected. Do I need a new alternator ?
