This is from my Bravo 1.6 mjet 88 kW from 2009. there is the original 120A A I dont know what producer.
However strange things when I do measure the voltages.
I presume this is the D4 ( it have two wires that came with thick cable from alternator ) connector so open it and start the engine. Everyting was ok no battery warning light on. Measured voltage on battery = 14.2 volts.
The electrical steering works.
Strange because I was expected the alternator not start to produce electricity.
On blue wire on female part of connector 14,2 v same voltages as + terminal of battery. On blue wire male connector 13,7volts.
On white wire 0.05 volts to negative battery terminal.
Stop engine ,key off, measured the resistence of the two wires from male connector to negative batt terminal ( earth ). No link between the two wires and earth.
So put the ignition on ,engine not start 0 volts on both blue and white cable from male ( presume one of this wire is from D+ alternator terminal.
On female connector 12.2 volts on blue wire ,0 volts on white wire. My battery is pretty old.
Key off, connect both parts of D4 connector, key on without engine starting 12,1 volts on blue wire and 0 volts on white one. Alternator warning light on.
Start engine and 13,8 volts on blue, 0 volts on white everythink ok, no warning light, steering works.
So the conclusion is the things dont works as described in eLearn.
Also I presume the excitation of the alternator rotor came somehow from inside the alternator, or exist ( in my case ) another wire which brings the excitation voltage to the regulator from alternator.
