I've got a 2015 Panda Pop (basic model, no start-stop). Still using the same battery that came with it (nearly 10 years old).
When using my reg plate, Tayna, Halfords and Eurocarparts all recommend a 012 battery (207mm*175mm*190mm).
The battery that was originally fitted is only 175mm*175mm*190mm, which Tayna thinks is a 002L.
The recommended battery will probably fit (same height and width, just a bit longer) should I just get a Varta 012? The CCA / power figures are slightly more generous than the original battery that came with the Panda.
- Model
- Pop 1.2
- Year
- 2015
