the hobbler
Distinguished member
- Joined
- Jul 25, 2012
- Messages
- 4,353
- Points
- 1,094
As I have mentioned earlier in this chapter of bafflement and woe, the problem with most 'pattern' condensers is that they are crap! We have a company in the UK called "The Distributor Doctor" who have modern, high spec condensers made for them (among a lot of other things). When I was speaking to the Boss of this company re. a litttle project that I had, he told me that he had taken a 'pattern' condenser apart and found about 1-1/2 metres of wiring in it---his condensers have THREE metres of wiring in them! The original "O.E" condensers hardly ever gave a problem. One of his condensers, the "484249 with the long bracket" can, if the mounting bracket is given a little bit of a 'tweek', made to sit very neatly on the distributor, as per factory. Alternatively, one of the "Competition" condensers from either "Swiftune" or "Shacktune" because they have both a long 'feed' lead and a long 'earth' lead, can be mounted up by the coil, away from the enemy of 'pattern condensers---heat (the 'cooling' air coming from the engine).Update: i retarded the timing a little and it fired right up for me...no push back on the starter that i had been feeling. i just had the timing a little too advanced. I still haven't timed it properly but at least i got it to fire right up and idle although it still had the same issue of trying to die on acceleration. as i have shared i have literally replaced every part i could with new. the last item on my list was the condensor, which showed up a few days ago. i just replaced it and the car runs like before. i am simply beside myself. i don't see any signs on the points of a bad condensor but that is 100% what the problem was. i started today by messing with that timing and got it to where it would start and idle, just not accelerate. i replaced that condensor, fired it up and accelerated with no problem...just like new. i can't believe it. i want to go celebrate. 2 months of ****ing with this thing only to finally figure out it was a $5 part. LMAO
