Hello, when I first started the car, the oil light stayed on for 2-6 seconds, and the dashboard showed a "Low oil pressure" warning. The engine sounded off while the light was on, so I knew there was no oil pressure. Once the warning went away, the engine noise returned to normal.
I replaced the sleeve bearings and removed the rubber seal between the oil pump and the pickup tube
replacing it with a machined part like this upgrade: https://jtd-performance.com/en/product/oil-pump-seal-modification-jtd-tbi/
This helped a lot and the oil pressure builds up much faster, but the low oil pressure light still comes up for second at most.
Do you think anything else, besides a bad oil pump, could be causing that low oil pressure light to come on? I don't think its normal. The car is nearing 200k kms, but I don't think that the mileage is an issue as the engine is in decent condition. I’m using the recommended Fiat oil Selenia with the correct SAE 5W30. Filter is new and the oil pan and pickup tube are clean.
Any advice would be appreciated!
- Model
- Fiat Doblo 1.6d multijet 2 cargo
- Year
- 2016
- Mileage
- 200000
