- Joined
- Feb 16, 2005
- Messages
- 5,983
- Points
- 988
These things just get more complicated lol.
Fitted the alternator today, and it doesn't line up with the crank pulley in the slightest. It to far behind the engine, and the belt would have fouled the timing ring on the crank and probably killed the alternator bearings.
I thought about spacing the alternator further outwards, but then the belt would have fouled the engine mount! I presume the same would be true if I used the 16V alternator.
My solution is a bit of a hack, hence posting
I would prefer a more elegant fix.
What I have done is swap the crank pulley/timing ring from the 1108 onto the 1248....this means the timing ring sensor doesn't line up now though!!! SO I have cut a custom piece of metal, screwed it into place using the old sensor screw, and will then drill the plate to move the sensor further out. Getting the right gap and making sure its secure is going to be VERY important
Its an ugly fix but I can't see any other way around it
I possibly could swap the 1108 oil pump (whose casing holds the sensor I think) over to the new engine, but that means dropping the whole thing and removing the belt/timing etc!! Something I'm reluctant to do as it a lot of effort for an unknown.
https://www.fiatforum.com/showpost.php?p=1022315&postcount=43
The above show the difference between the pulleys. The Punto has the ring next to the engine, then the pulley, thats why the belt can't fit with it.
Dave, you fitted your alternator yet? Which one? Any problems?
I'll post pics tomorrow of it if needed.
Lets hope there aren't many more problems I encounter
Cheers,
Kristian
/edit
also got my micrometer on the exhaust....for anyone whose interested that sei ID is about 34mm and the Punto SS manifold is about 50mm!!!! can't remember the exact measurements this lat, but that about 33% larger!! Def can't keep the current system after finding that out
Cheers,
Kristian
/edit
