er, this isn’t a diesel forum, it’s the 2012+ Panda forum (but members are, of course, welcome to comment on specific engines and thoughts relating to such engines (which may - or may not - apply to other engine types)
I used to drive fast and hard. It wreaked havoc with all the cars mechanicals, but less so than you might imagine. My company cars were all hammered all the time. I could tell when they were serviced and indeed when the cam belts were changed. Being driven vefast, but smoothly didnt seem to cause any issues.
Punchline is, that with modern engines it makes little difference, but an occasional brief thrash helps keep it all mving.
I think people misunderstand egr, it's purpose is to dilute the oxygen with spent exhaust gas, meaning you can still keep good gas flow at proper revs, and cooler cylinder temps as there's less oxygen and fuel in there (as the argument was lower revs means lower combustion temps)I just want to check the comments about EGR coolers, as I understand these are cooled by the engine coolant, so if you are running and engine at high revs any EGR coolant effect will result in increased coolant temps and more heat for the cooling system to shift. Potentially increasing under bonnet heat and the heat in any hotspots.
I'd read that recently as well, apparently as modern engines are most efficient at wide throttle openings, that it's better for economy to accelerate and slow down than to trundle along on part throttle.just remembered a ‘trick’ I used when I did a lot of motorway driving
- accelerate to above desired speed (mpg readout drops, but only for the few secs this took)
- then ease back throttle and watch readout climb to high mpg, car v slowly reducing speed, maybe a minute)
Repeat.
I'm with you on this, in a 30mph zone I'll be in 3rd if there are potential hazards, only in 5th if it's a long clear stretch.Also (not covered here) is the matter of safe driving i.e. being in the right gear at the right time
I ignore most of what I read, and find out for myselfI'd read that recently as well, apparently as modern engines are most efficient at wide throttle openings, that it's better for economy to accelerate and slow down than to trundle along on part throttle.
Seems surprising to me, and a counter-intuitive way to drive. Did you find it worked?
Fair point. I'll admit to being a bit ignorant about modern car tech.ignore most of what I read, and find out for myself
Waze, the free satnav now gives you a 0.3 mile warning that you're approaching a 'reduced speed zone' -- generally fro 30mph areas but opcciasionally for some 40's too......I've often thought it would be a good idea to have maybe a mile advance warning when approaching a village on a fast road so we can ease off gently rather than jump on the brakes.
I do that on roads I know, but then you get Audi-doodies up your chuff trying to accelerate hard towards a 30 zone![]()
In my dinosaur brain more throttle = more fuel but I'm learning maybe it's not so straight forward with a modern ECU?
That it's better to accelerate quickly to your cruising speed?
Repeat.
Because it’s all about averages. This way I could get low 40s in my Octavia 4x4. But it took effort and concentration, and not feasible on a busy motorway.
Some birds fly this way too - presumably to conserve energy/get more “mpg”! - eg green woodpeckers: 3 flaps (bird rises) then glide (bird descends) then 3 flaps etc
What possible evolutionary advantage could our strange proclivity for driving small, relatively unreliable Italian cars confer?And remember, no creature exhibits a particular behaviour unless it conveys an evolutionary advantage - in this case, conserving energy (what we call “economy”)
A strong sense of community through shared hardshipsWhat possible evolutionary advantage could our strange proclivity for driving small, relatively unreliable Italian cars confer?![]()
the engine is at its most efficient at converting fuel into movement at full throttle around peak torque.
That's interesting, makes sense. I have a tendency to build speed gently, but now I have an excuse to fully open the taps on the Pandathere's a loss of efficiency associated with the partially open throttle blocking/altering air flow and reducing the amount of work a given amount of fuel does.
Right! Drive like a woodpecker it isMimicking a flight technique observed in solitary birds like green woodpeckers
FWIW, I’ve just completed a 1500 mile road trip in my 2020 15K miles TA, from the north of England to Austria and back. For almost all of the trip ECO was on, climate was off, and I was driving at steady motorway speeds on E5 petrol. I was expecting to see an improvement on the upper 40s mpg I get “around the doors”, but the indicated average for the trip barely moved: just 50.
Interesting data point. My TA 4x4 2013 does maybe 38mpg running around home and with Mrs Panda eyes driving. I can get it into the low 40s without too much effort but it seldom does long runs so hard to know if it can be bettered. E5 definitely improves things. I don't indulge the ECO button! Of course the fuel mapping may have changed over the years too(?)FWIW, I’ve just completed a 1500 mile road trip in my 2020 15K miles TA, from the north of England to Austria and back. For almost all of the trip ECO was on, climate was off, and I was driving at steady motorway speeds on E5 petrol. I was expecting to see an improvement on the upper 40s mpg I get “around the doors”, but the indicated average for the trip barely moved: just 50.
