General How much is too much?
Is free advice still good when it's wrong or they have a hidden agenda?
Why not? Free advice is free advice, no?
My experience is that those two outlets serve their advice with a large helping of upselling (especially, tyres, exhausts and suspension/brakes). Just my experience.
I did unfortunately have to get some tyres and an alignment done at KF once - I had to show the technician how to loosen the tie rods and the tyres were scrubbed within 2 months after. After some discussion I did get the tyres replaced but never will go back...
Our local kwikfit used to have one redeeming feature, they were open until 9pm, handy for emergency tyres when you work. Now they shut at 5pm, so no point
I've always been OK with Halfords and Kwik Fit, on the basis they don't do any work at all.
I'd be much less inclined to trust ATS though, I sit in their office and wait for tyres to be replaced and I can tell from the phone calls I get to listen in on that they're not the best.
.I had hope the worst was behind me, as most said, but it never seems to end and I can't tell if this is just a car thing and my family has just been insanely luckily previously (mums car has broken 2 times in the past year and it made her almost sell it & my sister's old car had a coolant issue, the only issue after ~3 years of ownership) or this car is just a money pit.
Personally, my views on Pandas (169 & 319) are that they're very well built, being galvanised, and 1.2 engine is tough.
Major corrosion, engine and transmission issues are unlikely, which counts a lot for me as I tend to run older cars.
But they were built down to a price with a lot of cheap components that can fail with age. At 10 years old, yours is now at the age when those things are failing.
Parts are cheap, labour is expensive. I think you need to be able to do your own maintenance to run an old Panda economically. Even more so with a 100hp.
Is there a local or uni car social you could join to learn? Or maybe a course?
I'd suggest (personal order of preference) Mazda 2, Suzuki Swift, Toyota Yaris, Kia Picanto/Hyundai i10 would spend less time in the garage.
Regarding the noises, throbbing noise could be anything (although I wouldn't have thought alignment or tyre wear). Wheel bearing would be low continuous rumble, if front then worse when cornering. Does it change with road speed or engine speed?
Squeaky brakes is disappointing with new discs, pads, shoes & cylinders. I'd be tempted to take it back.
Only thoughts are new pads can sometimes squeal, or if the old drums were put back on, they might have a rusty lip on the inside that's catching the new shoes.
That.
I wouldn't keep a Panda beyond 10yrs old unless I could do all my own servicing and repairs. Fortunately it's a straightforward car to work on.
As far as rust is concerned, the core bodyshell is good for 15yrs+, but some of the bolt on bits, particularly the sump & rear twist beam, corrode badly and are unlikely to last that long without additional protection.
The 1.2 engine is bombproof unless run with insufficient coolant, but there is a metal pipe in the cooling system which is also rust prone and likely to need replacing at some point in the car's life.
