The Wifi OBD adaptor i s a limmiting factor in this investigation it is running at the same speed as my BT but only measuring 5 PIDs at a time not allowing some of the comparisons would have concidered eg comparing the Freeze frame data with air and turbo info, but hey ho. something i hadnt concidered previously.
These values are just outside the FIAT limmits of +- 2
From my Guide on
DPF Differential Pressure sensor Diagnosis with MES
What is an acceptable figure for DPF Differential Pressure (measured in mbar)? The answer is as little as possible. But if it flatlines at zero its dead.
Adding back pressure will make the engine work harder, and use more fuel to deliver the same power.
<20 Brilliant DPF causing almost no restriction
20-99 Good result and typical of a DPF in good working order
100-250 DPF causing up to 0.25 BAR of pressure – needs investigation
250-500 Serious restriction probably not allowing car to do a Forced Regen
So above graph is typical of a working system
The max and mean temperatures are good, the graph is typical of an engine getting upto temperature and not blocked.
The valve opens mostly Max to Min but does have some intermediate positions. This was not obvious with other results as these are inbetween the collected results. Is it blocked? IF there were more intermediate positions (1-3) i would say no. But with these values i will look at some other results first.
