Bit of an update, the Quaife LSD arrived last week so was fitted to the gearbox which in turn was fitted back to engine and now the engine and box have been fitted to the car.
Rear suspension has been put back on with old dampers and some Eibach springs we had so we can see what the anti-roll bar looks like and to see where to modify it further, the brackets will be remade and drop links moved up and bar will sit slightly higher now we know how much clearance we have to play with.
Also stuck some picks up of the short shift system, the gearstick will be shortened slightly which again will shorten the overall throw of the gearchange, but rather than just shorten to get a shorter shift, a pivot point was moved and this meant the cable is now sat in its own custom mount about 20mm higher than it was before, clearly shown in pictures, this decreases the thrown fore and aft by some margin, though will have no effect on side to side movement, but having the 6 speed box this is not really an issue as they are stacked fairly close so having some movement helps to prevent selecting the wrong gear, but again we needed to trial fit everything with a seat to see where it would fall, the steering column is also being dropped slightly, about 15-20mm in accordance with everything else.
Forgot to add for those wondering, the throttle body is a Ford one of unknown origin, but its pretty big and Jon has made a custom mounting plate to fit it to the Fiat inlet manifold, and an accelerator cable mount for it to sit in, the end is correct fitment for quadrant. the pedle movement is shorter than standard so may need to make a throttle stop for the pedal to ensure against stretching the cable.
