Punto (Mk1) Project R the Mk1 Cabrio Restoration project
1998 Rosso Red Mk1 Punto ELX Cabrio, that has been very neglected.
Project page for my 1998 Punto Cabrio Restoration project. This car was aquired in October 2023, with no service history and in a pretty poor state, however they are becoming extremely rare now in the UK, just a dozen or so of the 1.2 16v models left on the road and about 30 or so cabrios in total.
Pictures are from the forsale add and ones the previous owner sent me before I got it.
There is also a leak in the exhaust somewhere under the car, so I my look at getting a new exhaust including a new manifold, have found a nice 4into1 pipe for about 135 euros.
I am also looking for a 4-1 or 4-2-1 stainless steel manifold. Have you found one? Because on eBay I've only found one for the 1.2 16V mk2 engine and I'm not sure if it fits correctly for the 176B9.000...
Add in the throttle body from a 1.6 and some light porting/polishing and the engine will be able to breath a lot easier.
Would the throttle body be easy to install?
The horrible cast iron exhaust manifold it currently has fitted is only likely to be costing power. Assuming the engine is otherwise healthy then 100hp should be within reach.
Yes! Combined with a better air intake, and a stainless pipe with a resonator after the cat it could be possible!
I have seen a mk2 with the same engine on youtube with printouts showing 110hp with an uprated cam
True, but are we sure it is the 176B9.000 as the mk2 is a different model?
I'm afraid no, the mk1 has a different bolt pattern from all the later stuff.. I've been through all this recently, even the places that say they do them when you order them they actually dont and they just held onto my money for a while and then refunded me. Supersprint and CSC both still list them but dont actually sell them.. I have found one though but not been in position to buy it financially so can't tell you if quality is any good or not, I am planning to order one though at some point
Huge thanks for this sharing, I'll try to buy it on February, as you said with the last days of 2024 coming I'm not financially capable of buying it right now.
Also I'll try to do a dyno test before installing it
