As an update to my own scenario;
For background, our MH is a 2018 Rapido 696F built on a Fiat Ducato Chassis. The engine is an X290 2.3 150 Multijet with a comformatic gearbox. We bought it from new so all the miles completed are ours and we know its full history. Our MH has done 51k miles and has traveled in Europe, Morroco, and the UK including the Islands of Scotland. So a large variance in terrain, temperature, etc.
We also have a Blue Spark Engine tuning device, Early in our MH purchase we found the uphill torque in the mid to high gear range pretty useless. The device we have works really well and we certainly notice the difference.
The start of our 401/ 238 and finally the 402 fault codes began on our journey to Greece in April this year. We had done around 47k miles when we first started to receive the 401/ 238 fault codes. The symptoms were pretty much the same as most of those described in earlier posts on this thread. We would start a journey and within the first 10 minutes (normally when in 4th gear) a 401 followed by a 238 fault would occur. I already had a basic OBD reader so I was able to clear the fault codes and continue our journey which in most cases continued without further fault codes occuring. Some days later we started to receive the 402 fault, easily identified by the ridiculously slow limp mode the vehicle is put in.
On arrival in Greece, I started to carry out some research (a lot of research actually) on the fault codes and came across this forum, and thankfully this thread, started by
@Fredastaire. Beginning with the 'easy' options first and before we started our return trip to the UK some months later, I replaced the MAP and upon arrival to the UK, I replaced the Turbo Solenoid. Individually the changes I carried out made no difference. Each journey I made I would trigger 401/ 402 and 238 codes. I finally bit the bullet and invested in the
MES software and OBD hardware that was mentioned by
@Fredastaire and
@theoneandonly.
I carried out a number of journeys running
MES and sent the data over to
@theoneandonly for analysis. After numerous journeys and analyses, it became clear in
@theoneandonly opinion, my LP EGR Cooler was blocked. These are the final LP EGR graphs taken on 18/11/2023
@theoneandonly can provide a more technical explanation though as I understand the actual position of the LP EGR should be between 0 and 4.7 and also somewhere in between. These graphs show the position hitting and exceeding 4.7 more often than not. Indicating a potentially blocked LP EGR Cooler.
I purchased a replacement cooler via eBay and for reference took a picture of the filter just inside the cooler as shown below this one is quite clear.
On the 21st of November, our MH went into the garage to have the LP EGR Cooler replaced. Not an easy task as those who have already gone through this stage can testify. 2 days later (we also had a few other jobs done) we collected our MH. I kept the old cooler which I will clean in preparation for an inevitable replacement further down the road. Hopefully in more than 50k miles!!.
I took a few pictures of the old LP EGR Cooler and as shown in the following photos the cooler is pretty sooty I was also surprised by its weight. It seemed to be heavier than its replacement weighing in at 1526 grams.
I haven't had the opportunity to carry out a lengthy journey though we have one planned before the end of the week. After collection from the garage, I set up
MES and carried out a few shorter journeys.
@theoneandonly has the data from those journeys and I await his interpretation. Whilst waiting and out of curiosity I loaded the data myself and produced the following graph.
With my very limited knowledge, I can see that there is definitely a change. I will wait for
@theoneandonly to come back with the proper analysis.
In summary, and for our scenario; was having the LP EGR Cooler replaced worth the cost and time? The initial data points towards the 'yes it was' answer. Some longer runs in the next few weeks will hopefully enforce that answer. As with
@theoneandonly and
@Fredastaire, I am running our MH with an additive and will continue to do so.
