Fredastaire
- Joined
- Dec 19, 2017
- Messages
- 272
- Points
- 98
Van is 2017 Euro 6 bought new , now with 26K on clock.
Problems started this summer with dash engine light and code P0401 appeared on a country lane at low speed going into a corner so it would be low airflow going in to the engine as it wasn’t ‘working’. Bought FCR and cleared fault, happened again days later, including P0402, cleared it.
So its an intermittent fault., it might be days before it happens again. Dealer had a look, diagnosed software needed latest issue which he installed.
Still getting P0401
Then going up a hill with foot down a bit I get a double whammy of P0401 and P0236 plus P0238 and the dreaded limp mode.
After much reading on here I decided to but MES software for laptop and checked things, both EGR’s cycle fine, DPF is cycling fine and not blocked so scratching head and thinking, more reading on here and I decided to change the top high temp EGR thinking it was sticking. Brand new Fiat part from Coastal Motorhomes fitted and codes cleared, still intermittent getting P0238 P0236 and Limp Mode.
More reading on here led me to check the fine bore plastic vacuum / pressure pipes, all fine, more reading so took the left hand intercooler pipe assembly off suspecting cracked bracket, perfect, looked inside cooler, not blocked, visually checked the RH intercooler pipe – fine, checked intercooler – fine.
Ive ordered new Fiat MAP and turbo vacuum solenoid, yet to arrive.
I would appreciate comments and advice as to what I do next, Ive been told @whineO or @Euroserve might be able to advise, is it possible?
Still getting P0401
