Technical Upgrading Standard Speedo to Digital
Ok.
So what do you expect to change?
So that the ECO button works like the SPORT button. In sport mode, there should be a boost pressure sensor on the right side of the instrument panel. Or do I need to change byte 65=60?
Yes, MES did not make a PROXY and left the standard value of the ECO button. AlfaOBD was also unable to change ECO to SPORT. Maybe in cars of 2018 a different byte needs to be edited? MEC and AlfaOBD only know older BODY?
I doubt the sport
You won't get boost pressure if there isnt a boost pressure sensor connected.
I dont think the twinair has one has it?
It´s been 2 years, but I don´t think I did a proxy align.
I placed screenshots of normal and Sport mode here:
No need to change any bytes. I changed it here. (Sorry for the horrible screenshot)
That's what I did. After changes in MEC, the PROXY alignment procedure does not work, error
PROXI ALIGNMENT PROCEDURE
Writing CAN configuration data ...
Writing to module Body Computer Node (BCM/NBC) FAILED! - Request out of range error
[102A] errors: Byte 83: 08->00
Writing to module Dashboard Node (IPC/NQS) SUCCESS!
Writing to module Airbag Node (NAB/ORC) SUCCESS!
Writing to module Entertainment Telematic Node (ETM) SUCCESS!
FAILED TO EXECUTE
Thanks for the link, I wondered what the difference was. At least my eco gauge works, thats something I suppose.
At the time I didn’t know that the Eco gauge is actually fed by the radio, which I replaced with an aftermarket unit. So that explains why it stopped working 😁
