Just looked at the tyres and it says made in france so michelin is french!well u learn somthing new every day! Is there an british alternative ?
1150 single or 1090 dual is dual meaning for twin wheel? ... british alternative ?
I’ve no MH or RV experience – so running ≥ max L&I is unknown to me.
I’m aware some folks come-back-off the max pressure to trial a possible pressure e.g. 90% of max – but wasn’t aware a tyre manu. would advise running on max. My understanding is you can overload a wheel, but not the axle – e.g. a 2 tonne axle with one wheel at 1.1 & the other at 0.9 … over-inflate the 0.9 to the same as the 1.1, but the individual max L&I shouldn’t be exceeded. A dual is a twin wheeler on same axle – but I believe with a tag rig you can please yourself whether you use the single or dual from an L&I table.
I’m searching for something in English Law on this topic – e.g. when there’s a `disappointing incident’ involving an MH with tyres outside the L&I tables, what’s the outcome?
Avon? Tirerack list the source of the Agilis as Italy.
Edit: I've found L&I data for 215/75R16 C & CP tyres here ...
Motorhome tyres & your safety
http://www.tyresafe.org/images/tyre-safety-guide/motorhome-leaflet.pdf
101849Z
His head bowed,his feet shuffelling he was suitably chastised! Ahh
But if the EU has its way and forces people to replace their tyres every two years or so (which i read in the mail, so it must be true) surely it makes sense to go for the cheaper option and as i said i will be almost fulltime so not a lot of standing around.
... and to give you a different perspective ... that clears up a few points for you.
Have today took delivery of 4 michelin camper tyres ...
2.2 is way too low dangerous even.Hi people,
last week I have bought a Ducato 244(my first van)
Thx to the forum I have found the owners Manual
So I check the tyre pressure , and it's wrote 4 Bar (rear & Front)
But i'm little chock because I check the pressure of my tyre and it was 2.2 Bar
(I bought it from a Fiat Dealer so I was thinking it was the good pressure, and when i'm looking at my tyre the shape seem correct)
So I'm actually under pressure ? or 2.2 is correct ?
info
Tires = GoodYear Cargo G26 (max pressure 4.48Bar)
4 bar is correct, if I'm lightly loaded I will sometimes run a little less 3.6bar in the back for comfort.
well on my recently purchased Michelin tyers it says,
made in Poland,
Eric
