My 2021 Ducato Australian Series 7 2021 2.3 160 Multijet XLWB - "Maxi" was delivered with TPMS sensors fitted to only 4 wheels, not the spare.
Does your Ducato have TPMS, and if so, fitted to 5 wheels? Are all 5 working - have you tested all 5? A local company that sell aftermarket sensors incl. for the Ducato have advised that if the vehicle can only support 4 sensors, "having 5 sensors present with only 4 memory locations available may lead to the incorrect wheel being learnt into the wrong location(i.e., spare in place of a wheel that is on the road)."
AlfaOBD reports two front, two rear and an apparently empty spare slot, so I'm guessing I could add the fifth? It'd be handy to know if the Ducato is delivered in some markets with 5 sensors. FYI Australia does not mandate TPMS, would you believe.
Code:
Left Front Tire Sensor Altitude Compensated Pressure: 5325.00 mbar
Right Front Tire Sensor Altitude Compensated Pressure: 5200.00 mbar
Right Rear Tire Sensor Altitude Compensated Pressure: 5325.00 mbar
Left Rear Tire Sensor Altitude Compensated Pressure: 5350.00 mbar
Spare Tire Sensor Altitude Compensated Pressure: 0.00 mbar
Front left wheel identification: 01EFxxxx
Front right wheel identification: 01EFxxxx
Rear left wheel identification: 01EFxxxx
Rear right wheel identification: 01EFxxxx
Spare wheel identification: 00000000
