Re: tyre pressure
Full load in my handbook for 15" is 2.1 bar (1.9 normal)
handling like **** should be an interesting discussionmine run between 38-40PSI on 205/40/17, someone told me to lower it because it was too much but when i did the car handled like ****.
I would've checked with Continental again - unless you know that you have some special type of summer tyre (anyway, this should've been mentioned before).
If you prefer stiff car, then start from suspension, not from tyres - my advice.
Full load in my handbook for 15" is 2.1 bar (1.9 normal)![]()
handling like **** should be an interesting discussion![]()
Your ultimate ability to stay on a road surface should be increased if you use the recommended tyre pressures. Increasing the tyre pressure reduces the tyres footprint so it's very difficult to see how this would IMPROVE road holding.
Not a lot in my books but I did say this would get interesting.There's a difference between handling and road-holding.
Sorry Phil, but I think you've just quoted figures for 16" wheels.Ok reading this post again I realise morty is on 15" wheels and I quoted for the 17" wheel so for the 1.6 on 15s its 2.3 bar all around fully loaded just thought I would clear that up![]()
Argonought said:I'm afraid I agreeAll the more strange is that Morty drives on snow quite a bit I gather
nidza said:I don't beleive that a handbook says for 15" regular tyres to be inflated up to 2.7 bar. I am driving cars half of my life and have never seen such a nonsense.
Morty, that's a good summary but tyre pressure should be measured when cold and when the manual refers to 'hot' it means really hot i.e. like after a long motorway run and not just driving a few miles down the road.The instruction book also says 0.2 bars should be added to winter tires in addition to the 0.3 bars. This results in 2.6 bars on winter tires. This shows I've been driving on too low pressure on my winter tires.
this will sound stupid but that PSI right?There was a post somewhere about this stick 36/7 in the fronts and 35 in the rears..![]()
