Technical  Fuel pressure diagnostics
(y)
I finally received new multimeter leads so I'll be able to measure if the sensor and regulator get correct voltages - Chroma has more information in ePer than Stilo.
With the engine idling and warm, with all the consumers off and the accelerator pedal not operated, the pressure regulator opening (MPROP) must be less than 45%.
The test can be considered over"
Engine at idle, temperature = 70 degree, outside temperature 2 degree. Then push accelerator pedal to 2500 rpm for 20 seconds and idle again. You see also the graph of high pressure sensor voltage. MRPOP = 34.5 at idle and 32.3 at 2500 rpm.
Thank you!
It seems my regulator is working 😭
Try to measure again the fuel pressure sensor. As you see in the graph, when the output of sensor = 2 volts, the real pressure = 663.7 bar and this is happen at 2600 rpm not at idle.
Indeed. Seems almost illogical.
Today I swapped in a used original in-tank pump and the pressure is back to normal. The Delphi FG2435-12B1 pump I had installed before is listed as compatible with my car and engine in their own catalogue...
