I find it quite scary the number of cars you see around with obviously soft tyres with the sidewalls rubbed away as a result.
Tyres are things which need to be taken care of, checked often for cuts and damage and pressure - which should be run at or around recommended pressures.
I was nearly involved in a big accident on a motorway not so long ago, as a result of a driver not taking care of his tyres, and being numb enough not to realise he had a totally flat rear tyre at 90mph. That was the end of his car and crash barrier, along with a couple of passing cars too. I just narrowly avoided it, as it all happened a few metres infront of me.
So it pays to know your tyres are in their best condition, at all times!
You can't really argue with basic physics. As soon as you remove air from the tyre then the footprint must increase. If you're simply saying a greater load is taken by the outside of the footprint at lower pressures then fine
Obviously, there comes a point when the increased grip you get from low tyre pressures is negated and in any case it's a really bad idea to go outside tyre manufacturers recommendations (they should know):
- poor handling due to soft sidewall
- very high rolling resistance
- heavy & uneven tyre wear
Yes, i agree with you there.
You need to get a happy compromise dont you, too low and you will scrub off the edges in no time, more heat will be built up which increases the chance of a blow out, steering will be more vague, grip could also be effected as the tyre is rolling over onto its sidewall and its making extra drag.
Too much can cause a hard ride, wear to the centre of the tyre, more likely to damage an over inflated tyre front driving up/against curbs (although just as easy with underinflation), blow outs can also be common, as when the tyre heats up, it will be at an even greater pressure.
So all im saying, is tyres are not to be played with, they need care
