Thanks for that, the wife's wheels are 14 inchers and I definitely can't be bothered to whip a wheel off again just to try and find out if it fits properly in the well. Therefore, super skinny stays!
It won't take a full size 195/50 15" or a 195/45 16". I've tried.
Oh I know, but to be fair, if you're driving around Dartmoor in the middle of the night, I'd rather have a proper wheel to shove on other than some poor excuse for saving a few quid or so called weight saving by the motor manufacturer. Not only that, you aren't completely compelled to buy a new replacement (if puncture is not repairable) as soon as possible because of the limitations previously mentioned. I'd rather have the option of sitting down and trawling the internet for a good price than coughing up more than I have to, but then that's me, I'm just tight!
Jaime, apparently if you remove the plastic trim around the tailgate hatch you can just squeeze a 16" alloy into the space, (see link below).
http://www.abarthforum.co.uk/500-abarth-tuning/spare-wheel/
Standard 16" Abarth wheel fits in the wheel well in boot. To fit you need to unclip a plastic panel at rear of boot which is easy & refit with wheel in place.
Well I realised that they had changed my correct tire pressures from 36 front 34 rear to 30 front and 30 rear!
ahmett, I believe, after conversion from Front 2.2 bar - Rear 2.1 bar, the correct tyre pressures are 32psi front and 29psi back in normal conditions. However, the dealer has obviously checked the pressures on the service, which is comforting to know, despite having been set incorrectly, but it does prove that it is always a good idea to check such items yourself.
If you feel that the extra ride harshness you get with higher pressures along with the increased wear on the central tread of your tyres is acceptable to get the handling characteristics you prefer then that is entirely your decision.
ps. The above are based on cold tyres and if you are checking yours when hot then the difference between your preferred pressures and recommended pressures will be smaller.![]()
