Spannerhappy
- Joined
- Feb 21, 2012
- Messages
- 9
- Points
- 1
Hi all,can anyone offer suggestions to my problem?I have a Ducato with 190000 and up until last week was going strong. I tried to start it on morning and it started but only got about 100yards up the road before stalling. It starts fine and revs with ease . If i keep the revs over 2000rpm it keeps running but under this it stalls. Not straight away- it seems to give about 10-20 seconds of engine before it cuts out and thats on tick over or on revs. A turn of the key and it starts again. I've replaced the pressure regulator sender with a new one with no effect so was wondering if it could be the lift pump relay? I know the pump works as I can hear it (and I made sure it was delivering fuel too) but I've read somewhere that it runs to prime for 20 sec or so from start, then is switched on by a relay. Please correct me if i'm wrong and if anyone can point me to that relay is it would be appreciated. I'm sure its not the injector pump as the van will rev to over 3k before it cuts out. Pretty sure its not the EGR as i have already experienced problems and am getting pretty good at remove and clean(lasts for about 20kmiles with regular redex treatents) Also I have removed and cleaned the MAF again with no effect.
