Hi
as seen in the video, it takes about 8 s for the starter motor to receive the voltage with the driver actively holding the key in the "start the engine, will ya" position. Which means the ECU seems to be waiting for something to "clear" in order to safely sent current to the relais which feeds the starter motor. Now, which sensor signals would impede the ECU from engaging the starter motor? There must be some algorithm for it to go through.
I asked ChatGPT about this
In a Fiat 500 POP 1.2 with the Dualogic transmission, the ECU (Engine Control Unit) checks multiple sensor signals and conditions before authorizing the starter motor relay to engage the starter motor. These checks ensure the engine and vehicle are in a safe and operational state for starting. Below are the key signals and conditions typically evaluated:
1. Neutral Safety Switch (Gear Position Sensor)
- Purpose: Ensures the car is in the proper gear (typically neutral or park) to prevent the vehicle from moving unexpectedly.
- Signal: The ECU checks the transmission position sensor to confirm the gear lever is in "N" (neutral) or "P" (park).
2. Brake Pedal Position Sensor
- Purpose: Ensures the driver is pressing the brake pedal, a safety measure in automatic and semi-automatic transmissions.
- Signal: The brake pedal position sensor must detect sufficient pedal pressure.
3. Immobilizer Signal
- Purpose: Verifies the vehicle’s key is authorized to start the engine.
- Signal: The immobilizer system communicates with the transponder in the key via the Body Control Module (BCM). The ECU requires a valid signal to allow starting.
4. Battery Voltage Level
- Purpose: Ensures the battery has enough charge to operate the starter motor.
- Signal: The ECU checks the battery voltage via internal diagnostics. Insufficient voltage may block the starter.
5. Engine RPM Signal
- Purpose: Ensures the engine is not already running.
- Signal: The crankshaft position sensor must confirm the engine is at rest (e.g., near 0 RPM).
6. Clutch Position Sensor (if applicable)
- Purpose: In semi-automatic transmissions like Dualogic, the clutch position is monitored.
- Signal: The ECU checks that the clutch actuator is disengaged, which is controlled by the system itself.
7. Safety Interlock (Door Status or Other Conditions)
- Purpose: Ensures that other critical safety conditions (e.g., door status or hood status) are met, though this varies by model.
- Signal: The ECU may receive inputs from door or hood switches to verify safe operation.
8. Crankshaft and Camshaft Position Sensors
- Purpose: Although not always mandatory for authorizing the starter motor, some systems pre-check these sensors to ensure the engine timing data is available.
9. Error Codes in the ECU
- Purpose: Prevents starting if there are critical errors, such as a detected fault in the transmission system or ECU.
- Signal: The ECU runs a self-diagnostic and blocks the starter motor relay if a critical issue is found.
