Guys, (My 2008 GP Eleganza).
Found the remnants of what looks like a puddle under my passenger seat. Appears to be a vent under each front seat.
My guess is the drain tubes under the scuttle panel was blocked.
- The driver side tube I cleared a few years back so it must had help stop the water pooling.
- The passenger side tube that directs the water away from the brake cylinder was full of mud. I removed the pipe and gave it a good cleaning.
I emptied a bottle of water and the tubes are now free flowing.
I notice another issue that will eventually (if it hasn't already), create electrical issues. There is a soft rubber sponge like material on the each side of the scuttle panel that is suppose to push the water into the scuttle panel holes. Mine look so worn that the water is flower past and drips onto my loom be the fuse box.
I'd like to get these two sponges replaced. Anyone have an idea what these are called, and possible the part numbers? I may get the old silicon tube out for temporary fix.
Picture below so you know what I'm on about.
