Technical panda 1.3 multijet motor-number : where to be found ?
mydieselpanda
belgium
Hi everyone,
I try to import a belgian panda 1.3 multijet 51 Kw 2005 in Portugal and the technician at the technical inspection wanted to actually see the engine-number (188A800) on the motorblock. We could not find it. Back home, I even removed the whole air-intake module but nowhere on the engine can I find this xxxxxx number ......
Does anybody know where it can be found ???
Thanks a lot !
Model
panda 1.3 multijet 51Kw
2005
Here in the UK it's on the V5C registration documents
And also on the VIN plate in the boot, to the left of the spare wheel
Third line up
Only the engine model number not it's serial number here
Yes you can
It's here this is the 1.3 mj from a 500
Just below the crank sensor bottom right
Here's the sensor looking down the driveshaft and slightly below, not the greatest photo, bottom right is the sensor top right is the wiring connector being disconnected
You can just about remove the screw holding it in on a lift
So you must be able to photograph directly underneath it
Ok, thanks to you all. You're great !
I'll have to see if I can continue the import process without this in-situ verification (and this seems quite impossible at an MOT site).
This thread can be closed
Once again, thanks to you all !!!
One last message : after blindly cleaning the area around the sensor and taking a lot of pictures from various angles (without seeing exactly what), I had 1 picture with the number clearly visible.
I went back to the inspection and showed the picture. And then -incredibly- the guy came back with a functioning endoscope and he to saw the numer.
I got the final paperwork and this step in the import-pocedure is Ok now.
All this thanks to your help !!!
