Technical Panda 1.1 airbag light after hitting sewage shaft
yes, this exact one, had 7.5 written on it, I checked it in my owner's handbook; it's completely fine sadly, that means the reason lies somewhere deeper
If you pull the fuse out have you got power going to to one side
We need to know if we have a problem before or after the fuse
Which airbag light
Passenger yellow
Main red
Or both
The module is located here
Disconnect the battery first
red one, yellow is fine - shows up if i engage the passenger airbag disable feature with the key, otherwise doesn’t show
Airbag ECU must be up and running
The switch in the glovebox is connected directly to it
And the information to switch the light on and off is sent via the canbus network
theres also two earth's for the airbag ECU Infront of the module
I would bet my shirt on this being a code clearing job only. If there is no major damage there isnt really anything to be damaged but the shock could have upset an ECU module or sensor and something decided to fire off due to the shock. It has maybe partly activated a sensor and now it thinks it has a fault. The MES software from Gendan.co.uk is worth its weight in gold and in the UK mine has paid itself back at least 10 times over,. We have 3 and latterly 4 Fiats in the family so it gets quite a lot of use. Each use saves at the very least £25 and in UK saves much more. Do a search on here on Gendan and see what everyone has to say of them and the MES product. If you keep the car two years it will pay you back easily and is of course re sellable. HAving teh software allows you to see what is going n in the engine so even when things are running right is gives you peace of mind.
Gendan are a UK diagnostics disributor 🙂
FES (MES) Is a great Hungarian product licence for MultiECUscan is 50EURO..A Bargain 👍
