Hi Jock, I am not sure about the earlier ones, was the Austin A50s 1200cc you mentioned the very early B series? I remember doing a clutch on a Austin Devon pick up and the nuts and bolts (Whitworth?)that held the bellhousing, there was one right behind the distributor that was a pain to access, that and column change rods in the way also. The fact it was a local farmers work vehicle, covered in cow crap and I was working on a outside ramp/pit in winter time didn't help!
I did have a look at an old Haynes for Mk 2 Cortinas, but most of them were crossflow 1300cc and 1600cc, I think the 1100cc was a crossflow in the Fiestas. That agreed with you at 65/70ft lbs, so maybe the "old timers disease" hasn't quite caught you yet
The Mk 1 Cortina was 1200cc and 1500cc pre crossflow and Anglia 105E was 997cc and 1200cc pre crossflow, there was a Ford Classic which had a 1340cc or 1500cc engine. The 1500cc was the strongest engine as it had a 5 main bearing crank all the other pre crossflow were three bearing including the 1340cc which allowed me to make a 1340cc capacity of one of my 997cc Ford Anglia engines simply by changing the crankshaft and conrods to increase the stroke, so externally looking at the engine it was a 997cc, though as I kept the original 997cc cylinder head even with 5 star petrol pinking due to the very much higher compression and my driving soon knocked the bottom end out of it!
Another bit of useless information I have just recalled was those pre crossflow Ford engine blocks had a casting number and the number nearest to the highest T12 was the thickest block for any oversize boring etc. I had an excellent little book at the time called Tuning Small Fords.
We always used Glasses Technical Service Books, I was sorry when Auto Data took over, I had a pile of the Glasses TSD a foot high and should have kept them. It was the 75ft lbs I seemed to recall from there, but as the bosses had a strong family connection with the local Ford dealers maybe that was their preferred setting. Though they didn't pay highly , they were very good to work for and I learnt a lot from them, also they allowed me to use all the facilities for my own vehicles evenings and weekends
Here is a question, can you remember the first clutch job you did on your own,? Mine was a 1147cc? Triumph Herald and with the seats right back you did most of it from inside the car after removing carpet and largest "compressed cardboard" cover held in by lots of tiny screws and you undid the front bolts of the propshaft only , then pushed it to one side.
