ShiftyGeezer
Hi all. Had to replace my old Ford Ka and decided a red Fiat 500 would be a cool car to have. A very local seller happened to have one, so I bought it at a good price. At the time, the clutch was really stiff but I booked it in to my garage on 6th March for a health check.
Well, since then it's gotten a bit rough. Changing gear has been fine but I've sometimes struggled with clutch control, unsure of the biting point and not comfortably matching revs. At first I put this down to a new car feel, given I've only driven Ford Ka's before. I've only driven 2 trips in this motor, 40 miles total. Yesterday, the clutch seemed looser. However, at a busy junction, stop/start traffic, I stalled a couple of times and then couldn't fully disengage the engine. Took the back routes home and the clutch seemed to work, but reversing into the garage, the biting point seemed to slip lower and lower until again I floored the clutch pedal but it wasn't fully disengaging.
I've search the web and this forum threw up a few similar experiences. I just checked the Clutch Fluid level and it's full. It's quite a dark colour. I also tried changing gear and I can move the stick without pressing the clutch pedal. Is that supposed to be possible? I thought the gear stick was supposed to be physically locked in place. Next step is probably a fluid replacement, but I'm not up for bleeding it. Is there something I can do to get it good for taking to the garage (10 mile drive)? Is it worth replacing the clutch fluid in the reservoir without a proper bleed? Is there a trick like pumping the clutch that'll get it 'good enough' to make the journey?
- Year
- 2011
- Mileage
- 60000
