Communicator
Prominent member
- Joined
- Aug 3, 2019
- Messages
- 2,885
- Points
- 785
As far as I can ascertain the 1.9TD was only produced with indirect injection. Such engines where reputed to be smoother running that direct injection engines, but always required glowplugs when starting from cold.It is a 1.9 TD engine or was
Many years ago I changed the combustion chamber inserts on my diesel landrover. These inserts had a group of long pimples opposite the injector which aided combustion by retaining heat. The inserts were a tapping fit into the head, but as I remember they partially overlapped the cylinder wall.
If the 1.9TD is similar how could an insert drop out of the head? This has been puzzling me since it was mentioned earlier. Perhaps cracks developed in the insert, which was why I changed mine.
