Communicator
Prominent member
- Joined
- Aug 3, 2019
- Messages
- 2,841
- Points
- 771
This is suggesting that there is no connection between D+ on the alternator and connector pin A52 on the BCM.No light comes on, on the panel.
I do not know how the BCM is programmed to respond to no connection with D+, but in the nomal course of events it expects to see about 1K Ohm, and will the send the initial excitation to the alternator. The BCM monitors the D+ wire for the correct voltage, and turns off the warning light when the output reaches the correct value.
From a previous thread, I believe that forum member @koalar has considerable knowledge in this area. Perhaps he may be able to make further suggestions.
