I changed the engine oil and filter yesterday. For the first time I discovered the used engine oil to come out with a "clunk, clunk, clunk" as no air was able to come in to the engine. I had not loosened filler cap. Is this normal? Should´nt the oil breather let the air into the engine? Is there any intervals of changing oil breather filter?
And then, when finishing the oil change, I started the engine without the filler cap, and I think it was a lot of air pressure coming out of the filler hole. Engine has 60.000 km after total overhaul. Some thoughts and knowledge, anyone?
