Update: had the B&M disconnected this week! Seems to have stopped the new battery from draining - still have flashing milometer but no problem for me as I like a good disco! Thank you all for your help - this is a fantastic forum! Much appreciated!
Hi everyone!
Have had the B&M module disconnected and car been fine so far - i can live with the flashing odometre!...
However, one of my daylight running lights has gone....have the lovely yellow triangle on digital display and well as 'check running lights' when start the car! All adds to the disco effect!!...
Not fussed about the DrL's but i wanted to turn off them off so they're both off BUT....when i tried to access the MENU to turn off DLR and take off the yellow triangle , it doesn't appear!.....and so I have the yellow sign and 'check running lights' alert when start car....
I didn't expect to lose access to the MENU once the B&M module disconnected....should this have happened?
Also, if i have the DLR light replaced (or it could just be loose wire) would the alert automatically reset? I can't remember if it automatically resets itself without accessing the menu...
I am also thinking ahead about tyre pressure so if I had to reset the menu for tyre pressure then I wouldn't be able to access it...
Is there a way to get the menu back?...
Complicated little cars!
Thank you John! But it's the whole menu function that has gone - normally I can reset the DLR to on/off using the menu but when I went to the menu it would not appear - didn't realise I would lose this once B&M module disconnected.....so to get rid of the yellow triangle alert I would have to fit a new DRL? Obviously can't reset it as I don't have a menu! This is definitely a downside to the B&M module disconnection...I've heard before that the drl off option has disappeared, guess you'll have to replace the bulb?
And no, option to get it back
Probably just the headlight angle adjustment. It cycles through 0-1-2-3 using the menu up/down buttons.Also, a number has appeared on my headlight icon - is there a reason for this? What does this mean?
Granted - but it relates only to the headlights, not the DRL's.Of course the number and angle adjustment is nothing to do with actually losing the on/off function!
Thank you Piccolo - that's how I feel - upside down! i will cycle through and set it on 0!
It;s a decision I had to make -either remove the B&M or have the battery drain again - there's some good info on this on the forum - i opted to remove it but i still have flashing odometer which is fine - the actual job of removing you could probably do yourself - i watched the mechanic do the surgery onmy car and i I had the confidence I reckon i could have tried it - it's all about removing the casing and then fitting it back - it took her no more than 45 mins to do everything and I was chatting so he could have done it all I'd say in 30 mins!Granted - but it relates only to the headlights, not the DRL's.
I was contemplating having my B&M module removed when I (eventually) fit a new head unit but your experience has put me off the idea. At the moment the B&M is fully working - and not draining the battery!! - but if doing the proxy thing afterward removes my ability to control the DRL's than I won't bother.![]()
Hi Varesecrazy, thank you for asking! Yes it seems to be holding up well but the temps have been quite mild - it is a new battery - the old one lasted for 8 years or so - i's the original one so it has done really well and it is only cos of the darn Blue&Me palava that I had to replace the battery - but i do think that had I had the resource to jump start the battery or trickle charge it, the old one would have rejuvinated! The car is running good so far! I can live without my Blue&Me and I do have a flashing mileometer but it doesn't bother me! The guy who disconnected the module was super efficient - did it in less than an hour nd it was only the panels that took the time - had they been easy to remove and refit I reckon he could have disconnected it within 15 mins! Disconnecting the B&M module was the right thing to do and the most cost efficient! Thank you very much for the help you gave - it is much appreciated! Have a great New Year!
