Same system as the panda
First don't panic, the vast majority of power steering faults are normally simple and cheap fixes especially if it starts failing mainly in your winter months But unfortunately nobody can say change this or do that and it fix it. A lot of different faults will cause the same symptoms or the...
www.fiatforum.com
The fact it fails from first start then doesn't fail again strongly suggests it the battery
There's no easy test, substitution for a known good is the most reliable test
The fact it fails from first start then doesn't fail strongly suggests it's not the alternator
The only reliable test for the earth strap is a voltage drop test under load, unless it's obviously corroded or damage.
Over on the panda section someone struggled on for two year, because the garage twice told them the battery tested okay on their gadget
